E Body Rear Defogger question? #958278
03/25/11 02:39 AM
03/25/11 02:39 AM
moparAL Offline OP
moparAL  Offline OP
On a 70-74 Ebody does the switch engage the defogger continuously or does it shut off (automatically) after so many minutes. If so how many minutes? Also does the defogger just blow air over the rear window or is there a heating device somewhere in the process? Thanks everybody
Re: E Body Rear Defogger question? [Re: moparAL] #958279
03/25/11 02:55 AM
03/25/11 02:55 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It will blow continously. Two speeds, IIRC.
The coil next the blower is a resistor. It does not heat the air in any significant manner. Just takes air from inside the passenger compartment sucked through the speaker grille and blows it on the back window.
Re: E Body Rear Defogger question? [Re: autoxcuda] #958280
03/25/11 03:06 AM
03/25/11 03:06 AM
moparAL Offline OP
moparAL  Offline OP
Thanks for the info Steve-
