Mini Starter install...starter shield ?..not heat #958139
03/24/11 11:59 PM
03/24/11 11:59 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
Installing motor and tranny next weekend(440/727) and don't know if I will need a started shield. I don't have one and need to know where to get one if I do...anyone??
If it matters I ordered a "NEW" starter for a '92 Dakota w/5.2
THNX!!!
Re: Mini Starter install...starter shield ? [Re: moparrulzzz] #958140
03/25/11 12:14 AM
03/25/11 12:14 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I wouldn't bother,myself and most other run em for years before any problems. they are cheap and easy to rebuild anyway.
Re: Mini Starter install...starter shield ? [Re: moparrulzzz] #958141
03/25/11 12:57 AM
03/25/11 12:57 AM
Central TX
roe Offline
roe  Offline
Central TX
I just wrapped mine in some of that heat reflective tape from the parts store. Actually seems to work pretty well
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Mini Starter install...starter shield ? [Re: roe] #958142
03/25/11 03:16 AM
03/25/11 03:16 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
May not need it,but there was one available for the Magnum engines.Sorry I do not have the PN.
Leave the gun.......take the Cannoli's....Mike
Re: Mini Starter install...starter shield ? [Re: mike s] #958143
03/25/11 08:55 AM
03/25/11 08:55 AM
Mansfield,Ohio
Mansfield,Ohio
I guess I should clarify, I am not looking for a heat shield. I found this pic on 440 source.Do I need one of these?
Re: Mini Starter install...starter shield ? [Re: moparrulzzz] #958144
03/25/11 08:47 PM
03/25/11 08:47 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
You will be fine with out the shim. I run one on my Super Bee only because I still have the origonal. I don't run one either of my race cars.
Re: Mini Starter install...starter shield ? [Re: Dabee] #958145
03/25/11 09:21 PM
03/25/11 09:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I figured it helped keep sh*t out of the bellhousing
Re: Mini Starter install...starter shield ? [Re: Stanton] #958146
03/25/11 10:21 PM
03/25/11 10:21 PM
Mansfield,Ohio
Mansfield,Ohio
