42LE routine trans service, FWD #957867
03/24/11 07:00 PM
03/24/11 07:00 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Trans is working properly. Just some new ATF+4 and a filter change? Or are there any internal adjustments while the pan is off? Does not to be any band adjustments like the ancient stuff.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 42LE routine trans service, FWD [Re: GO_Fish] #957868
03/24/11 08:46 PM
03/24/11 08:46 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
The 42le is just fluid and filter,no adjustments. There is also gear lube in diff that can be changed.
