disc brakes #957697
03/24/11 01:49 PM
03/24/11 01:49 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..Any body convert to front disc from drum and keep the drum master cylinder?
i used a Disc/Drum master cylinder on the duster when i went to front discs and my level hasn't dropped at all in a thousand miles.
..so how many miles before you would have to add fluid...most of us don't put a lot of miles on these cars yearly?
..how do you remove the 101b residual pressure valve?
Re: disc brakes [Re: can.al] #957698
03/24/11 05:11 PM
03/24/11 05:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Disc brakes, all depends on the wear of pads. Might be fine for a long time.
Re: disc brakes [Re: can.al] #957699
03/24/11 07:03 PM
03/24/11 07:03 PM
Happy Birthday RapidRobert  Offline
the drum M/C is fine & that caveat was for liability issues and aimed at the general motoring public who may go for a long period WO checking fluid levels. Stick a drill bit into the brass seat & you'll feel the RPV if it has one & thread in a screw & carefully lever out the cone w 2 large screwdrivers/toss the spring and valve & press the cone back in (keep it straight) & use the male inverted flare fitting on the brake line to seat it
