Rattle & buzz, 46rh
#957373
03/23/11 10:59 PM
03/23/11 10:59 PM
Posts: 154 Winlock, Wa
fshd4it
Winlock, Wa
My 95 3/4T pickup with a 360, noticed a rattle in all gears at 1500-2000 RPM yesterday. I'm guessing at this 'cause I don't have a tach. Worst when accelerating from low speed/stop, almost like detonation. Today when I was running the truck through it's gears in the driveway it starts to buzz in reverse, but no other gears. I can make it much more pronounced by "powerbraking" in reverse, then throttling up from idle. Into the shop, drain the trans (ATF-4,15 months/15k old,looked a little darker than I'd like), nothing in the pan or filter. Spotless,almost. Both bands still right on for adjustment, shift linkage and throttle pressure adjusted correctly, flex plate bolts tight, no dust shield contact. Any ideas before I dig deeper? Oh yeah, did I fail to mention it's got 229k and never been touched...
In order to know what you want, you'll probably have to find out what you don't want.
Re: Rattle & buzz, 46rh
[Re: Dcuda69]
#957375
03/24/11 12:52 AM
03/24/11 12:52 AM
fshd4it
Winlock, Wa
Yep, I'm a little concerned about the torque converter, I've heard/read the factory ones leave a bit to be desired. Good point about the cat, but mine's an empty shell. I rodded it out after it clogged a couple years ago. I need to climb under the truck in the morning and shake the tar out of everything to find the rattle, but as for the buzz?
[Re: fshd4it]
#957376
03/24/11 10:49 AM
03/24/11 10:49 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
if it does it while power braking, get a vehicle operator to do that while you lay on ground NEXT to the vehicle and try to look up under it to ID the source.
do NOT lay where the vehicle may drive if something goes wrong--if it's in reverse, stay on the sides or in the front, and out of the way of the tires!
**Photobucket sucks**
[Re: Dave Watt]
#957378
03/24/11 01:22 PM
03/24/11 01:22 PM
fshd4it
Winlock, Wa
I pulled the dust shield and checked the flex plate to converter bolts, good and tight. From the motor side the flex plate looks fine, don't see any cracks,etc. I wanted to drain the converter, too, but evidently this one doesn't have a plug. Found a few other sites that refer to the buzz in reverse issue (even a TSB to go with it), doesn't sound like I should worry too much. The two noises probably aren't even related. At this point I think I'm gonna filter & fluid it and let 'er roll. Funny thing is I bought a torque converter and a complete kit for this trans 5 years ago, still sitting on the shelf. Sometimes my luck and my common sense don't travel down the same path...
