Manual steering box ? #957308
03/23/11 10:27 PM
03/23/11 10:27 PM
KS
68SportSatvert Offline OP
KS
Will a manual steering box from a 68 A body fit a 68 B body? Thanks!
Re: Manual steering box ? [Re: 68SportSatvert] #957309
03/23/11 11:16 PM
03/23/11 11:16 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
All the boxes interchange but if your going from power to manual or vise versa, you have to have the correct coupler and shaft, or the adapter.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Manual steering box ? [Re: 68SportSatvert] #957310
03/24/11 01:43 AM
03/24/11 01:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it will but make sure the a body donor is not a slant 6 , it has bushings instead of bearings, not as heavy duty.
Re: Manual steering box ? [Re: 68SportSatvert] #957311
03/24/11 03:58 AM
03/24/11 03:58 AM
They will but make sure the pitman arm is correct for the car and body style If there not the same order a new one from NAPA or some other good parts houses
Re: Manual steering box ? [Re: Cab_Burge] #957312
03/25/11 01:15 AM
03/25/11 01:15 AM
KS
KS
Thanks! JohnRR - You gave me the info I didn't know I needed. The car is a /6 car so I guess I'll pass. Thanks again!
