04 Durango Code P0138?? #957097
03/23/11 05:15 PM
03/23/11 05:15 PM
Holly/MI
Dean_Kuzluzski Offline OP
Holly/MI
04 4.7 Durango
Code P0138? Voltage high?
O2 sensor, Bank 1, Sensor 2, lefthand side? Front or rear?
Is there 2 or 4 on these trucks?
Re: 04 Durango Code P0138?? [Re: Dean_Kuzluzski] #957098
03/23/11 06:09 PM
03/23/11 06:09 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
PO138 is for the left rear 02 per the service manual....
trying some attachments:
Rich H.
Esse Quam Videri
Re: 04 Durango Code P0138?? [Re: Dean_Kuzluzski] #957099
03/23/11 06:13 PM
03/23/11 06:13 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
For a complete wiring diagram Refer to Section 8W.
When Monitored:
O2 Sensor Heater Temperature is greater than 496°C (925°F) and battery voltage greater than 10.99 volts.
Set Condition:
The Oxygen Sensor voltage is above 3.99 volts for 30 seconds. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
(K141) O2 1/2 SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(K904) O2 DOWNSTREAM RETURN CIRCUIT SHORTED TO BATTERY VOLTAGE
(K141) O2 1/2 SENSOR SIGNAL CIRCUIT OPEN
(K904) O2 DOWNSTREAM RETURN CIRCUIT OPEN
O2 SENSOR
PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING).
Diagnostic Test
1. O2 SENSOR ABOVE 3.7 VOLTS
NOTE: When only one O2 Sensor is shorted to voltage, the scan tool will display all O2 Sensor voltage readings at approximately 5.0 volts. When diagnosing this DTC, only diagnose the O2 Sensor that set the DTC.
Start the engine.
Allow the engine to reach normal operating temperature.
With a scan tool, read the 1/2 O2 Sensor voltage.
Is the voltage above 3.7 volts?
Yes
Go To 2
No
Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
Perform (NGC) POWERTRAIN VERIFICATION TEST VER - 5.
2. (K141) O2 1/2 SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
Start the engine and allow the engine to idle.
Disconnect the 1/2 O2 Sensor harness connector.
Measure the voltage on the (K141) O2 Sensor 1/2 Signal circuit in the O2 Sensor harness connector.
NOTE: Measure the voltage in reference to ground, not the (K904) O2 Downstream Return circuit.
Is the voltage above 5.2 volts?
Yes
Repair the short to battery voltage in the (K141) O2 Sensor 1/2 Signal circuit.
No
Go To 3
3. (K904) O2 DOWNSTREAM RETURN CIRCUIT SHORTED TO BATTERY VOLTAGE
Turn the ignition off.
Disconnect the C2 PCM harness connector.
Ignition on, engine not running.
Measure the voltage on the (K904) O2 Downstream Return circuit in the O2 Sensor harness connector.
Is there any voltage present?
Yes
Repair the short to battery voltage in the (K904) O2 Downstream Return circuit.
No
Go To 4
4. O2 SENSOR
Connect the C2 PCM harness connector.
Connect a jumper wire between the (K141) O2 1/2 Signal circuit and the (K904) O2 Downstream Return circuit in the 1/2 O2 Sensor harness connector.
With a scan tool, monitor the 1/2 O2 Sensor voltage.
Is the voltage between 2.3 and 2.7 volts with the jumper wire installed?
Yes
Replace the O2 Sensor.
No
Go To 5
NOTE: Remove the jumper wire before continuing.
5. (K141) O2 1/2 SIGNAL CIRCUIT OPEN
Disconnect the C1 and C2 PCM harness connectors.
CAUTION: Do not probe the PCM harness connectors. Probing the PCM harness connectors will damage the PCM terminals resulting in poor terminal to pin connection. Install Miller Special Tool #8815 to perform diagnosis.
Measure the resistance of the (K141) O2 1/2 Signal circuit from the O2 Sensor harness connector to the appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
Yes
Go To 6
No
Repair the open in the (K141) O2 1/2 Signal circuit.
6. (K904) O2 DOWNSTREAM RETURN CIRCUIT OPEN
Measure the resistance of the (K904) O2 Downstream Return circuit from the O2 Sensor harness connector to the appropriate terminal of special tool #8815.
Yes
Go To 7
No
Repair the open in the (K904) O2 Downstream Return circuit.
7. PCM
NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay particular attention to all Power and Ground circuits.
Were there any problems found?
Yes
No
Replace and program the Powertrain Control Module per Service Information.
Rich H.
Esse Quam Videri
Re: 04 Durango Code P0138?? [Re: Dean_Kuzluzski] #957100
03/23/11 06:14 PM
03/23/11 06:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Or....just put an 02 in it and hopefully that does it
Rich H.
Esse Quam Videri
Re: 04 Durango Code P0138?? [Re: ZIPPY] #957101
03/24/11 08:42 AM
03/24/11 08:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Zippy reading the flow chart made me laugh.Its funny that when we have to check something on new cars that we have to do all that stuff.Then people complain because you charge an hour to diag a problem.Most think that its our fault that it takes so long to really check something.Worst thing is thats a short diag compared to most stuff.Most people think all you do is hook up the machine and it tells you everything and fixes the problem.LOL Rocky
Chrysler Firepower
Re: 04 Durango Code P0138?? [Re: therocks] #957102
03/24/11 09:57 AM
03/24/11 09:57 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
And then you get the "(insert auto parts store name) will scan it for free"
Perfect, then take it to them and let them fix it !!!
Rick
Re: 04 Durango Code P0138?? [Re: Blown71X] #957103
03/24/11 10:36 AM
03/24/11 10:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They think just scanning will fix everything.Ive seen people guess whats wrong and spend a fortune.I guess its cheaper to just toss parts than to have it diaged properly.Rocky
Chrysler Firepower
Re: 04 Durango Code P0138?? [Re: Blown71X] #957104
03/24/11 10:41 AM
03/24/11 10:41 AM
Holly/MI
Holly/MI
Rick
A fine example of how people diminish the talent required to fix things.
The scanning of the codes is just a step towards isolating/defining the issue. Then the real work starts. True, you can "shotgun" it and be a "parts-changer" but that can get expensive. It's OK on the inexpensive sensors and modules. Troubleshooting, reading service manuals and "troubetrees", as we called them, separates the men from the boys.
Thanks Rich!!
Me? I'll throw down for a new sensor and try the shotgun method to save time and hope for the best. If that fails, break out the trusty digital multimeter and go down the so nicely supplied list as time permits.
Re: 04 Durango Code P0138?? [Re: Dean_Kuzluzski] #957105
03/24/11 12:03 PM
03/24/11 12:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Had an O2 sensor problem on my 03 Ram. Forget what the code was now but we "assumed" it was the sensor and swapped it. No dice. Turns out the harness was rubbing on the cat heat shield and had either gone open or shorted to ground, I forget which. Might be something to check before you go down the flow chart garden path. I now have a spare sensor .
Kevin
Re: 04 Durango Code P0138?? [Re: Dean_Kuzluzski] #957106
03/24/11 12:05 PM
03/24/11 12:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Anytime
I know how it is...been there
Re: 04 Durango Code P0138?? [Re: Twostick] #957107
03/24/11 01:58 PM
03/24/11 01:58 PM
Holly/MI
Holly/MI
Was just under there the other day looking at both sensors, just change the rh side. Harnesses looked fine. But thanks, it's happened to me too in other situations. Left over "Test-parts" are great. Live and learn.
Re: 04 Durango Code P0138?? [Re: Dean_Kuzluzski] #957108
03/24/11 05:33 PM
03/24/11 05:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dont you people know the scanner tells us what to do ?? Ron
