#956671 - 03/22/11 08:57 PM New brake drums needed
AeroMonte Offline
Loc: S.E. Missouri
I'm helping a friend rebuild a 69 Charger and he needs new front brake drums. The problem is he can't find any through the local parts stores. Where do you guys recommend? The brakes are 10x2 1/2.
#956672 - 03/22/11 09:47 PM Re: New brake drums needed [Re: AeroMonte]
ahy Offline
Loc: IN
Year One advertises them (expensive). Its a really good time to consider a front disk swap before spending money on the drums. See the Mopar Action website for a swap with OE components (JY or new) or Master Power Brakes for OE style kits or Behr Brakes or Dr Diff or others for "big brake" options.
The disks really do stop better.
#956673 - 03/22/11 09:53 PM Re: New brake drums needed [Re: ahy]
69Chrgr Offline
Loc: New Jersey
Drums are available from Napa, they are around 120 for the fronts, 50 for the rears each, look online at napaautoparts.com
Edited by 69Chrgr (03/22/11 09:56 PM)
#956674 - 03/22/11 10:08 PM Re: New brake drums needed [Re: 69Chrgr]
ahy Offline
Loc: IN
PS... if you want a set of 11 x 2.5" drums complete with backing plates and all internal brake parts shoot me a PM (70 E). They worked when removed.
#956675 - 03/23/11 05:55 AM Re: New brake drums needed [Re: ahy]
okie Offline
Loc: okla.
They have them listed in the new Classic Ind. catalouge.
25,628 Registered Members
195,544 Topics
Minneapolis area, Lifted 1st gen 1 ton , odd project
by bigdad
12/12/18 08:27 AM
Looking For Kick Down Linkage Experience
by Rodder
12/11/18 11:12 PM
Battery ID from broadcast sheet
by 340cpe
12/11/18 10:47 PM
Lower cylinder damage,ok to run?
by RTSrunner
12/11/18 10:14 PM
