cam plug #956594
03/22/11 08:02 PM
03/22/11 08:02 PM
ohio
geol Offline OP
geol  Offline OP
ohio
I just got my engine back from the machine shop(340).It is sitting on an engine stand angled slightly forward.I noticed a trace amount of moisture at the bottom of the cam plug.I wiped it up and it reappeared.Seems to be coming from the inside of the block.Any ideas?
Re: cam plug [Re: geol] #956595
03/22/11 08:09 PM
03/22/11 08:09 PM
Delray beach, Florida
P
Performance Only Offline
P
remove, clean the area and replace the cam plug with a new one and #1 permatex.
machine shop owner and engine builder
Re: cam plug [Re: geol] #956596
03/22/11 10:43 PM
03/22/11 10:43 PM
I wiped it up and it reappeared. Any ideas?
gotta pull the cam & the plug & have a look see. May need to strip it & clean it as they certainly missed something & who knows what else they skipped
Re: cam plug [Re: RapidRobert] #956597
03/22/11 10:49 PM
03/22/11 10:49 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
If yours is one of the flat metal ones you can replace it with one that has sides like the rest of the freeze plugs. I never use the flat ones, I dont trust them. The permatex is always a good idea. No place for a leak.
Re: cam plug [Re: Cudajon] #956598
03/23/11 05:57 PM
03/23/11 05:57 PM
ohio
geol Offline OP
geol  Offline OP
ohio
Thanks guys.Talked to the machine shop.They will replace.It was so small I hedged for a sec,but you're right not a good spot for a leak.
