Page 3 of 3 1 2 3
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956130
03/24/11 05:58 PM
03/24/11 05:58 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
The voltage regulator has been replaced and it's a small silver unit. I am guessing that it is already the electronic one??
I will convert it to the mini starter as well.
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956131
03/24/11 06:46 PM
03/24/11 06:46 PM
If the underside of it has wire wound resistors then it is the old electromechanical style
Re: Anybody running an Edelbrock 750 on their big block? [Re: RapidRobert] #956132
03/24/11 09:17 PM
03/24/11 09:17 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
I shall investigate further
Re: Anybody running an Edelbrock 750 on their big block? [Re: Dean_Kuzluzski] #956133
03/25/11 03:41 AM
03/25/11 03:41 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Soooo, what's that mean?
Are you poo-pooing the idea of spending around $20 or less to tune a carb before throwing down several hundred $$ for a Holley?
Others, see attached for the set of metering rod springs mentioned.......
http://www.edelbrock.com/automotive_new/mc/carbs_acc/access_calibrate.shtml
Your Joking , Correct ???
First Thing , I Never Mentioned Holley
Second Thing , I Could Tune A Edelbrock , Carter AVS All Day / Any Day - I Love The AVS Series Actually , Original And New - I Take The Original Factory Carter Avs,s and pull off the metering rod covers and make my own flat metering rod covers and tune them with the Edelbrock Metering Rods / Springs And Jets (Finding the Carter AVS Strip Kits , Three step metering rods and tall primary jets is next to impossible)
ANYWAYS with that said
The 1407 / 1411 Performer Series Is Nothing More Then A Overpriced Parts Carb - Actually Thats Beeing To Nice , How many beer cans could we make out of a 1407 Carb ??? That would Bee more productive and definetly a wiser choice
Bottom Line - You cant tune a internal design flaw with springs
That series , 1407 / 1411 is the most and WORSE talked about carb on Moparts.com - Probably the world wide web for that matter
For every 1 positive there is like 100 negative posts about those /1407 1411 series
Carry On
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Anybody running an Edelbrock 750 on their big block? [Re: bee1971] #956134
03/25/11 09:50 AM
03/25/11 09:50 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Hey, no problem here. Just didn't know what you were implying.
I never said the metering rod springs were the end all tuning fix that is solely needed. It just seems to get overlooked when people are struggling with a off-idle bog and they try jetting, pump squirt and everything else.
Just trying to help.
Everyone is entitled to an opinion, some just don't share it so well.
Re: Anybody running an Edelbrock 750 on their big block? [Re: bee1971] #956135
03/25/11 12:57 PM
03/25/11 12:57 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Carry On
well said, The older original Carter carbs were some of the best, the metering was well thought out, The 1407/1411 are Pieces of S, They took a good carb design & screwed it up, I'll take a Holley all day long over those things, I know i said i wouldn't make anymore comments, Oh well .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Anybody running an Edelbrock 750 on their big block? [Re: joedust451] #956136
03/25/11 08:32 PM
03/25/11 08:32 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
The question is...
We don't want to talk about holley...
I use Edelbrock 750 on my 451 and really work GOOD
Re: Anybody running an Edelbrock 750 on their big block? [Re: STROKIE] #956137
03/25/11 08:43 PM
03/25/11 08:43 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
The question is...
Can you tell me some of the things that you have done to it??
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956138
03/25/11 08:49 PM
03/25/11 08:49 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
Remove the Choke horn by grinding and you gone have a greater Carb...
Re: Anybody running an Edelbrock 750 on their big block? [Re: STROKIE] #956139
03/25/11 09:45 PM
03/25/11 09:45 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I guess "great" is out of the question, so you have to settle for "good", thats why i ran a "Great" carb on my 451
Re: Anybody running an Edelbrock 750 on their big block? [Re: STROKIE] #956140
03/28/11 05:43 PM
03/28/11 05:43 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Removing choke horn eh??
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956141
04/01/11 09:18 PM
04/01/11 09:18 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Here's the voltage regulator. Solid state type??
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956142
04/01/11 09:22 PM
04/01/11 09:22 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Here's the 78 Diplomat replacement alternator. This is a higher output model than the earlier ones correct?
What would I need to safely upgrade the wiring so that it can handle the added amperage?
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956143
04/01/11 09:44 PM
04/01/11 09:44 PM
This is a higher output model than the earlier ones correct? What would I need to safely upgrade the wiring so that it can handle the added amperage?
Yes higher amps & you have an electronic reg in the pic. Many ways to go w elec upgrades & myself I clean EVERY connection/terminal AND strive to keep the ammeter needle close to 12 o'clock and power added high amp draw accessories right from the alt w relays. #1 clean connections/terminals and keep high flow out of the bulkhead and if not then running 2 wires straight thru the bulkhead on the 2 main in/out lines (fusible link in/wire out to alt)
Re: Anybody running an Edelbrock 750 on their big block? [Re: RapidRobert] #956144
04/01/11 09:51 PM
04/01/11 09:51 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Thanks!
As an update, I looked at my lower alternator bracket and I don't think that it is correct. It does not have enough adjustment to get the belt as tight as it should be. I think this could be another issue. The belt is looser than it should be for sure.
Re: Anybody running an Edelbrock 750 on their big block? [Re: DusterKrazy] #956145
04/01/11 09:54 PM
04/01/11 09:54 PM
Yeah I ran into that & if all the bracketry is good I got a SLIGHTLY shorter belt (it dont take much). Take it in w you
Page 3 of 3 1 2 3
