2000 dodge caravan 3.3 flex, any dodge techs here #956047
03/21/11 10:30 PM
03/21/11 10:30 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
so we got the mini van in todaay, Its a rebuilt van (rebuilder title) any way it says no 5 inject circuit.. so we repaird the inj harness... and then repaced the 5 inj.. van still misses and shows same code... now im sitting at home going though all data.. and it says it could be the asd relay? if it checks good then ck wiring if thats good its the pcm.
anyone have this code before? what was your fix? I didnt now the asd relay could cause a 5 misfire inj circuit..
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: Dakota_Don] #956048
03/21/11 10:53 PM
03/21/11 10:53 PM
Alton, IL
Alton, IL
oh if the asd relay was acting up, would it set multiple missfires not just the #5 inj open code? P0205.
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: Dakota_Don] #956049
03/21/11 11:00 PM
03/21/11 11:00 PM
Alton, IL
Alton, IL
oh we also used a noid light, it pulses on number 5.. didnt see anything odd there
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: Dakota_Don] #956050
03/21/11 11:03 PM
03/21/11 11:03 PM
Staten Island, NY
Theorio1025 Offline
Theorio1025  Offline
Staten Island, NY
What do you mean by repaired the circuit? Was there a fault, or did you just replace the wiring? Have you tried scoping out the # 5 injector circuit? Also it may be a false code caused by a bad pcm.
Re: 2000 dodge caravan 3.3 flex, any dodge techs here [Re: Dakota_Don] #956051
03/21/11 11:06 PM
03/21/11 11:06 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
That is a "crossfire" engine. Make sure you have really identified injector #5. The injector will be on the OPPOSITE side of the intake from the #5 cylinder. Additionally, check for trash in the end of the injector rail. If trash gets past the filter it usually ends up at the back of the rail.
Good luck
Re: 2000 dodge caravan 3.3 flex, any dodge techs here [Re: DartGTX] #956052
03/21/11 11:25 PM
03/21/11 11:25 PM
Alton, IL
Alton, IL
ok here is what found when the hood was open..
towards the front, drivers side, the 6 inj wiring was frayed.. fixed that.. it ran better.. pcv hose off, fixed that.. now after the codes were reset.. it still has number 5 circuit mal-function. so i pulled the plenum off, checked the wiring under it.. it all looked good..ohmed out the inj and it was approx 12.9 range..used a noid light to check the wiring, it flashed as it should have. I dont think that inj is bad..it ohmed like all the others.. it has a bad miss, also if i pull number 5 wire off the coil pack nothing changes still runs the same.
fire wall
now the inj order is pass side 1-3-5 driver side
2-4-6
radiator
thanks again
Re: 2000 dodge caravan 3.3 flex, any dodge techs here [Re: DartGTX] #956053
03/21/11 11:28 PM
03/21/11 11:28 PM
Alton, IL
Alton, IL
so if i understood you right, number 5 cly which is in the back of the engine all the way towards the driver side/firewal isnt the number 5 inj? the number 5 inject is the one on the front driver side?
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: Theorio1025] #956054
03/21/11 11:30 PM
03/21/11 11:30 PM
Alton, IL
Alton, IL
i am thinking pcm, but wanna rule out all other posibilitys
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: Dakota_Don] #956055
03/23/11 10:30 PM
03/23/11 10:30 PM
Alton, IL
Alton, IL
turns out its the pcm causing this problem........ thanks
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: Dakota_Don] #956056
03/24/11 12:08 AM
03/24/11 12:08 AM
ill
dennismopar73 Offline
ill
hi don ,,
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: dennismopar73] #956057
03/25/11 10:39 PM
03/25/11 10:39 PM
Alton, IL
Alton, IL
hey dennis... whats up
Re: 2000 dodge caravan 3.3 flex with code p0205 [Re: Dakota_Don] #956058
03/26/11 12:46 AM
03/26/11 12:46 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
What is the diff between the regular 3.3 and the flex 3.3 ?
