Re: Fender Tag Decode
[Re: Moparmadman]
#955904
03/21/11 09:36 PM
03/21/11 09:36 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
This is all I got from mymopar.com:
LL29: Dodge Dart,Demon Low 2 Door Sports Hardtop
G3B: 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL 1973 Dodge Main, Hamtramck, MI, USA
516008: Sequence number
E44: 318 cid 2 barrel V8 230hp D34: Light Duty Automatic Transmission FE5: Bright Red Exterior Color F6L3: Trim - Luxury, Vinyl Bucket Seats, Parchment 000: Full Door Panels 601: Build Date: June 01 467208: Order number
V4W: Unknown Top Color V: Unknown A88: Interior Decor Group B41: Front Disc Brakes w/Standard 10in RR Drum C16: Console w/Woodgrain Panel C56: Bucket Seats
C73: 69 only Fold Down Rear Seat G33: LH Remote Racing Mirror H51: Air Conditioning with Heater L25: Trunk Lamp L31: Hood/Fender Mounted Turn Signals M21: Roof drip rail moldings
M52: Unknown N76: Coolant Recovery System N95: Emissions Control R11: Radio Solid State AM (2 Watts) V08: Paint, Trim, and Vinyl Roof Edit Waiver
V9W: Unknown Y84: Unknown 26: 26in Radiator
[Re: MuuMuu101]
#955905
03/22/11 12:27 AM
03/22/11 12:27 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
G3B: 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL G only tells you it was a 318-2bbl. More is learned by the engine code and model 1973 Dodge Main, Hamtramck, MI, USA
E44: 318 cid 2 barrel V8 230hp 150 HP D34: Light Duty Automatic Transmission FE5: Bright Red Exterior Color F6L3: Trim - Luxury, Vinyl Bucket Seats, Parchment 000: Full Door Panels 601: Build Date: June 01 scheduled production date not necessarily the actual 'build' date 467208: Order number
V4W: Unknown Top Color Halo vinyl roof; white V: Unknown should be "U" meaning built for sale in the US A88: Interior Decor Group B41: Front Disc Brakes w/Standard 10in RR Drum power front disc brakes C16: Console w/Woodgrain Panel C56: Bucket Seats
C73: Fold Down Rear Seat G33: LH Remote chrome Racing Mirror H51: Air Conditioning with Heater L25: Trunk Lamp L31: Hood/Fender Mounted Turn Signals M21: Roof drip rail moldings
M52: Unknown sunroof N76: Coolant Recovery System N95: Emissions Control R11: Radio Solid State AM (2 Watts) V08: Paint, Trim, and Vinyl Roof Edit Waiver V4W vinyl top was not recommended with the parchment interior
V9W: Unknown up and over tape stripe; white Y84: Unknown If this is correct then = new car service- dealer pre service 26: 26in Radiator
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
