904 Trans valve body Question #955721
03/21/11 05:49 PM
03/21/11 05:49 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I got a V8 904 trans with maybe a bad valve body & was wondering if thear would be any pressure differentes if you used a valve body form a 904 6cl ?
Re: 904 Trans valve body Question [Re: Hoop] #955722
03/21/11 05:53 PM
03/21/11 05:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No the VB should be the same , you could compare the distance of the adjusting plate on the pressure regulator between the 2 , otherwise throw it in and go .
Re: 904 Trans valve body Question [Re: JohnRR] #955723
03/21/11 06:06 PM
03/21/11 06:06 PM
scratchnfotraction Offline
non loc up vb in a non loc up 904
loc up vb in a loc up 904
should swap right in
Re: 904 Trans valve body Question [Re: Hoop] #955724
03/21/11 06:20 PM
03/21/11 06:20 PM
describe what's going on w it/how it's acting
Re: 904 Trans valve body Question [Re: Hoop] #955725
03/21/11 10:06 PM
03/21/11 10:06 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
well, fall 2009 it wint out on me & I had it rebuilt by my Mechanic with new disc, new, stock none lock up TC & some other stock parts that I had to order, but I had to get the Front Ring Gear from a good 904 6cl trans that I got, because the place I got the parts from did not have it & the VB should be Stock because it was never changed out. The problem is that it don't hold back when you pull it down in second gear & my Mechanic tould me its eather kickdown band needs readjusting or when it went out on me the metal going in the VB may have scratch it & he missed that when he had it apart, so if it is the VB then, I'm just going to use the one from my 6cl 904.
Re: 904 Trans valve body Question [Re: Hoop] #955726
03/21/11 10:12 PM
03/21/11 10:12 PM
it wont shift down into 2nd when you shift down to manual 2nd? And it did b 4?
Re: 904 Trans valve body Question [Re: RapidRobert] #955727
03/21/11 10:27 PM
03/21/11 10:27 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Yes, when you pull it down in second gear by hand it don't hold back, but drive works like it did & first holds back good, but second was holdin back just fine befour I had it redone!
Re: 904 Trans valve body Question [Re: Hoop] #955728
03/21/11 11:46 PM
03/21/11 11:46 PM
Hoop I've gone as far as I can & I'll have to defer to Kunkel from here.
