Stainless engine fastners ?? #955695
03/21/11 05:30 PM
03/21/11 05:30 PM
CentralVA.
BBCoronet Offline OP
CentralVA.
Has anyone used stainless engine fastners and had trouble with stripped or galled threads? I used some years ago on a SB Chevy and never had any trouble but a good friend of mine says they are nothing but trouble.......Any thoughts?
Re: Stainless engine fastners ?? [Re: BBCoronet] #955696
03/21/11 06:12 PM
03/21/11 06:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Haven't had problems in the smaller sizes up to 3/8-16, but I use anti-sieze or bolt-prep. I don't use SS in high-torque applications. I pretty much use them in areas where I'm concerned about corrosion, not on the #s (incorrect) or race (weight) stuff.
Re: Stainless engine fastners ?? [Re: topside] #955697
03/21/11 09:38 PM
03/21/11 09:38 PM
IN
ahy Offline
ahy  Offline
IN
SS and aluminum react resulting in stuck fastners and galled threads. Anti seize will prevent this as will locktite. Steel bolts are more resistant to this problem but still benefit from at least some oil when going into aluminum.
Re: Stainless engine fastners ?? [Re: BBCoronet] #955698
03/21/11 09:40 PM
03/21/11 09:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I have used stainless steel ARP bolts in my LS1 (intake, front drive brackets, engine mounts, headers..) and as mentioned used anti-sieze...no problems or sticking issues at all.
Re: Stainless engine fastners ?? [Re: OzHemi] #955699
03/21/11 10:20 PM
03/21/11 10:20 PM
CentralVA.
CentralVA.
Thanks for the replies........ I've used them without issue..... but he says no way, no how. Oh well...To each his own.
