2001 town&country,gauge cluster removal #955121
03/21/11 11:06 AM
03/21/11 11:06 AM
Newmarket, Ontario. CANAD
mopargord Offline OP
super street
super street
Is there any chrysler techs that could tell me how to remove gauge cluster on my T&C. Speedo needle went haywire when tranny self destructed and needle is now on "down side" of the pin it rests on when engine is off, need to figure out how to get it to correct side of pin so that speedo reads mph's.Thanks, Gord
Re: 2001 town&country,gauge cluster removal [Re: mopargord] #955122
03/21/11 01:49 PM
03/21/11 01:49 PM
Ohio
Todd Offline
Todd  Offline
Ohio
From the Service manual
REMOVAL
WITH ELECTRONIC TRANSMISSION RANGE INDICATOR
Disconnect and isolate the battery negative cable.
Remove Over Steering Column Bezel by lifting it straight up with a firm pull.
Remove the four cluster bezel attaching screws.
Tilt the steering column in the full down position.
Pull rearward on the cluster bezel and remove.
Remove the four screws holding instrument cluster to instrument panel.
Rotate top of cluster outward.
Disconnect the cluster harness connector.
Remove instrument cluster from instrument panel.
WITH MECHANICAL TRANSMISSION RANGE INDICATOR
Remove the lower steering column cover. Refer to Body, Instrument Panel, Lower Steering Column Cover, Removal.
Remove the plastic knee blocker reinforcement. Refer to Body, Instrument Panel, Knee Blocker Reinforcement, Removal.
Disconnect the transmission range indicator cable end from shift lever by flexing the HOOP on the transmission shift cable rearward and slip the indicator cable loop off the lever pin.
Disconnect the clip holding the indicator cable to the mounting bracket.
Remove the four bezel attaching screws.
Remove the four cluster attaching screws.
Rotate top of the cluster rearward.
Remove the instrument cluster carefully while guiding the range indicator cable and guide tube through the opening to avoid any damage.
Re: 2001 town&country,gauge cluster removal [Re: Todd] #955123
03/21/11 03:06 PM
03/21/11 03:06 PM
super street
super street
Thanks Todd! will give it a go. Gord
