Re: fixing leaking freeze plug
[Re: TheOtherDodge]
#955074
03/23/11 12:04 AM
03/23/11 12:04 AM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
you might look to see if it's the heater core leaking. a small leak would drip from the drain tube. clear the floor and lay some paper or cardboard down, and check for a leak after it sits for a few hours. might be easier to pinpoint the exact spot the drip is coming from.
[Re: dOc !]
#955077
03/25/11 01:05 AM
03/25/11 01:05 AM
Posts: 3,344 Central TX
roe
Central TX
Like guys here have said, "If one is going, they're all going". When one of mine went, I replaced just that one. Then when I got around to checking the rest, there were 5 other ones that were leaking and I didnt notice, or were so paper thin that just scraping it with a screwdriver put a whole in it.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
