#954989 - 03/20/11 10:23 PM ford rim on mopar or vice -versa
SSAAHemiFan Offline
Loc: USA
I looked at so many rims over the last week I have confused myself, I think #1 is correct??.
Is it
#1 - a ford rim can be used on a mopar.
OR
#2 a mopar rim can be used on a ford.
The reason I ask is I am looking at a set of these for the rear of my project.
They are offered in ford or gm size and are not returnable once ordered
#954990 - 03/20/11 10:26 PM Re: ford rim on mopar or vice -versa [Re: SSAAHemiFan]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
Its the center hub register that is the issue. Fords used a SMALLER wheel bearing, so FORD wheels fit Fords. The Mopar wheels have a larger center hub.
SHORT answer: Ford fits Ford
Mopar fits both.
#954991 - 03/20/11 10:26 PM Re: ford rim on mopar or vice -versa [Re: SSAAHemiFan]
1_WILD_RT Offline
Management Trainee
Loc: Today? Who Knows?
Mopar can be used on a Ford but if the center register is properly sized for the Ford the rim won"t fit a Mopar....
#954992 - 03/20/11 11:07 PM Re: ford rim on mopar or vice -versa [Re: 1_WILD_RT]
finadk Offline
Loc: East Brunswick, NJ
I used a set of Ford Mustang Rims on an 80 Volare. All I had to do was get a drum sander on my drill and open up the center hole just a little bit.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
25,708 Registered Members
196,895 Topics
Rubber Fitting for Small Block Water Pump
by MuuMuu101
01/23/19 11:14 PM
My car is a pig!
by mprhound
01/23/19 10:40 PM
Any 1/18 scale Mopar collectors out there?
by Gabmando
01/23/19 10:28 PM
Dodge RB 440 crankshaft question-
by Tek52
01/23/19 09:54 PM
