#954858 - 03/20/11 06:46 PM Degreeing cam question
68340GTS Offline
Loc: Blairsville Pa.
This was just a cam swap. Is it normal for the rotor to be pointing a little past the 3:00 position with a 4 degree advanced cam key installed with everything at TDC? First time for doing this but something doesn't seem right. Thanks
Edited by 68340GTS (03/20/11 06:52 PM)
#954859 - 03/20/11 07:04 PM Re: Degreeing cam question [Re: 68340GTS]
You're talking about the rotor in the distributor, right?
The rotor can be anywhere. Find top dead center and wherever the rotor is pointing is #1.
...or keep restabbing the distributor gear until you get #1 where you want it!
#954860 - 03/20/11 07:21 PM Re: Degreeing cam question
68340GTS Offline
Thanks. That is what I thought. My concern was this was just a cam swap and it was off that far from the factory key.
#954861 - 03/20/11 07:23 PM Re: Degreeing cam question [Re: 68340GTS]
RapidRobert Online   content
Loc: Lincoln Nebraska
W it dot to dot,(crank gear-12o'clock and cam gear-6o'clock) #6 cyl is ready to fire. Turn the crank slightly CCW till the marks are at 10 BTDC (15 if radical cam) as you need adequate cyl cranking psi then turn the dist till the nearest reluctor blade is dead even w the magnet AND the rotor is under (or close to) #6 plug wire terminal & yes you can reclock the inter gear to put the order anywhere you want but the OE order (SB I'm assuming, #1 forward and slightly to the pass side which'd place #6 to the rear & slightly to the dr side) is good standardization practice. FYI Some aftermarket timing sets have a complicated system of marks on the gears to denote straight up/2 or 4 adv/2 or 4 deg ret
25,708 Registered Members
196,876 Topics
Small Chrome Plating System
by jim6346
01/23/19 02:09 PM
1968 Dart conversion from sedan to hardtop
by maximus
01/23/19 01:15 PM
Tire Diameter Selection
by gzig5
01/23/19 12:08 PM
1971 Dodge 500 truckt i wish it was
by TNos
01/23/19 11:56 AM
