"Red Stripe" Gear Ratios #954791
03/20/11 07:08 PM
03/20/11 07:08 PM
Desert Tracker
HYPER8oSoNic Offline OP
Desert Tracker
Maybe this topic was covered already, but I'll ask
out of curiousity.
Just trying to get my information "correct" on the A-833 4 speed w/ Red Stripe gear ratios. Was this an option on the Magnum engined B" and E"
bodied 4 speed cars? And why is it so significant?
I would like more info on this ratio, since I am not familiar or fluent with A-833, other than general rebuilds (syncro, bearings, etc.). Any input (facts and opinions) would be helpful for my personal knowledge and "archives". Thanks!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: "Red Stripe" Gear Ratios [Re: HYPER8oSoNic] #954792
03/20/11 08:25 PM
03/20/11 08:25 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Red stripe ratios were: 2.65, 1.64, 1.19, direct. They were available for 18 spline four speeds and were an over the counter item to the best of my knowledge. Not installed in production cars. Maybe in the 68 S/S cars I'm not sure.
Sheldon
Re: "Red Stripe" Gear Ratios [Re: HYPER8oSoNic] #954793
03/20/11 08:26 PM
03/20/11 08:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
http://www.moparts.org/Tech/Archive/clutch/17.html
The gear ratios for that transmission are in the archives, however I have no idea what the application was in which you could get that trans.
Re: "Red Stripe" Gear Ratios [Re: DaytonaTurbo] #954794
03/20/11 11:09 PM
03/20/11 11:09 PM
Desert Tracker
Desert Tracker
Thanks! Now, I won't have to scratch my head as much. Great info! I'll try to research further about the
applications this ratio was applied to. Appreciate all the input!!
