Re: Coan super sprag for street, strengths/drawbacks?
[Re: lowflyingdart]
#954639
10/13/11 05:16 PM
10/13/11 05:16 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Put in either the Coan or the A&A 16 element sprag. It will be just fine on the street. The only draw back is cost. We had a customer break a rear end with a 727 and a Coan Supersprag. The Sprag held, but was damaged. Most importantly it held and didn't overrun the drum. Larry
mine is not for street use[heavy car3900# 1,000+ HP]
[Re: 440Jim]
#954641
10/14/11 12:18 AM
10/14/11 12:18 AM
Posts: 2,177 ill
dennismopar73
ill
all these do help but if and its always a matter not if , but when it goes it will take anyones sprag! most time the trannys junk either way, just make sure you run a shield!
[Re: dOc !]
#954642
10/14/11 08:17 AM
10/14/11 08:17 AM
Challenger 1
Cincinnati, Ohio
I think that the aftermarket sprags are just another way dip-DEEP into your wallet.
I would just INSIST on better track-prep ....
Always thinking someone is trying to rip him off, it get so old...
Yea sure there gonna prep the track better because you have weak trans, yea right.
[Re: Challenger 1]
#954644
10/14/11 01:01 PM
10/14/11 01:01 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
READ AGAIN
Short story, went to a regional outlaw track for a fun run/race. Poor track prep, hooked hard on drag radials, got out about 30 ft and the tires broke loose/hooked up again and busted my sprag
It was for FUN run not the world finals... track prep is usually 60' at your own risk.
I think the sprang and a griner V/B aka low band apply will be all the insurance you will need
[Re: Challenger 1]
#954645
10/14/11 01:12 PM
10/14/11 01:12 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
ChallyNONE ... why do you keep tryin' to bust-my-stones ? ESPECIALLY when you live-in such a glass-house(being in the LPG reselling biz) ... the most complained about energy supplier in the nation ...
AND now with your MAN CARD revoked ...
[Re: hemi-itis]
#954646
10/14/11 01:18 PM
10/14/11 01:18 PM
dOc !
Florida STAYcation
Doc is just bein' thrifty There are no drawbacks for an aftermarket sprag.
..and the hemi- should go on a gauge-weight DIET ! ..... ONLY reason to go to a aftermarket sprag is if your case is damaged and you can't use a OEM piece.
BUTTTT ... there IS a draw-back ...you are emptying your wallet uNnecessarly .... but if you want to spend your money IN ANY WAY you see fit ... go-ferr-it
[Re: dOc !]
#954647
10/14/11 01:36 PM
10/14/11 01:36 PM
Challenger 1
Cincinnati, Ohio
Very successfully I might add for 27 years now! What have you done sucessfully Doc?
[Re: Challenger 1]
#954648
10/14/11 01:45 PM
10/14/11 01:45 PM
dOc !
Florida STAYcation
Yeah ... you should have had your MAN CARD revoked YEARS ago .. What I have I done successfully ? ... ran a WORLD FAMOUS fiberglass business for years. And lately ? ... bought a few shares of Apple stock .... And I would not BE PROUD of LPG reselling ... they are famous for ripping-people-off. LOOK UP the Michigan AG records for the largest fine ever levied and paid ....Inergy PROpain ! WHY do you INSIST on getting and every time you come-after me ? You MUST like it .....
[Re: Challenger 1]
#954649
10/14/11 01:46 PM
10/14/11 01:46 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
Bottom line: your sprag is less likely to fail if it's a bolt-in. They're not that expensive and there really is no drawback in using one.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 440Jim]
#954652
10/14/11 03:13 PM
10/14/11 03:13 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
what a bunch of babies....geez. back to the sprag; my understanding is; 1. add a bolt in to prevent the oem from spinning in the case,or damaged case from one already spun 2.buy a "good" bolt-in if hi hp levels,[added rollers] more $$$$ 3.the cheap four bolts are avalible,for home do it your selfers 80.00\ and they have ferrels to kinda take up the hole to bolt slop 4.good ones have shoulder type and added number of rollers [c-6 unit] have CRT do the trans.. ...mike
[Re: Lee446]
#954654
10/14/11 05:00 PM
10/14/11 05:00 PM
Posts: 25,720 Rio Linda, CA
John_Kunkel
Rio Linda, CA
69 Satelite,528 hemi. This is mainly a street car and still uses a modified vb that retains auto function. Short story, went to a regional outlaw track for a fun run/race. Poor track prep, hooked hard on drag radials, got out about 30 ft and the tires broke loose/hooked up again and busted my sprag.
If the VB "retains auto function" it would still apply the rear band in 1st. Were you in Drive when the sprag failed?
[Re: Clanton]
#954656
10/15/11 11:57 AM
10/15/11 11:57 AM
Posts: 1,374 Houston,Tx.
Lee446
Houston,Tx.
Boy, this got resurected from way back! To answer your question John, yes, it was in drive. I have a 6500 governer in it and that is why I have a auto VB in it, so I can let it do its thing. I don't want to give up the column shift, which I have never been able to get tightned up enough to feel confident manually shifting without overshooting and I don't want a MVB. With a wedge, the car was deadly consistant in drive bracket racing, and I used it that way for years with no problems. I'm beginning to think I was just real lucky!
[Re: Lee446]
#954657
10/15/11 05:00 PM
10/15/11 05:00 PM
John_Kunkel
Rio Linda, CA
If you make a conscious decision to leave the line in Drive you risk losing the sprag...no matter who makes it.
