#954613 - 03/20/11 03:03 PM Is there an alternative for glass channel weatherstrip?
Black_Bee Offline
Loc: BC, Canada
Hey Guys!
I'm replacing the glass in my '69 Super Bee coupe and while removing the glass from the rear pop-out windows I noticed that the weatherstripping (thin plastic & covered in felt) at the front edge of the glass is cracked. I checked the other side and it is in the same shape. Same for the stuff used on the roll down side windows.
I see that this stuff is available to buy new, its just insanely expensive:
http://www.rtspecialties.net/proddetail.asp?prod=2932230
$69 per piece! Considering a car takes 4 pieces, $276 seems too expensive for these little pieces!
Is there some other less expensive source for this stuff? From what Ive read I believe that it all comes from Mopar and is priced similarly.
Has anybody used something else that might not be factory correct, but works fine?
Thanks!
Paul
Paul
'69 Super Bee 383
#954614 - 03/20/11 07:59 PM Re: Is there an alternative for glass channel weatherstrip? [Re: Black_Bee]
Xlr8us Rapidus Offline
super gas
Loc: Western NY
I am looking for these also. I thought I saw them for $29 or$39 somewhere. I gotta go look again.
#954615 - 03/20/11 08:56 PM Re: Is there an alternative for glass channel weatherstrip? [Re: Xlr8us Rapidus]
Black_Bee Offline
Loc: BC, Canada
Hey!
I wonder if this is the same thing:
http://www.autopartswarehouse.com/detail...mp;apwidp4NOJn3
Its certainly not OE style, but I couldnt care less as long as it fits & functions correctly
Paul
Paul
'69 Super Bee 383
#954616 - 03/20/11 08:59 PM Re: Is there an alternative for glass channel weatherstrip? [Re: Black_Bee]
ahy Offline
Loc: IN
Year One had two lines of window weatherstrip: standard replacement and "OE correct". The standard replacement was reasonably priced - worth having a look.
#954617 - 03/20/11 09:08 PM Re: Is there an alternative for glass channel weatherstrip? [Re: ahy]
Mopar_Country Offline
Loc: Under My Car
You could look here as well.
http://www.restorationspecialties.com/
#954618 - 03/20/11 11:09 PM Re: Is there an alternative for glass channel weatherstrip? [Re: ahy]
Black_Bee Offline
Loc: BC, Canada
Normally I don't use Year One, but they had a 30% off sale today... I had a few other things to order so I decided to just buy the pieces from them and stop worrying about it.
Thanks for the help!
Paul
'69 Super Bee 383
25,708 Registered Members
196,895 Topics
Rubber Fitting for Small Block Water Pump
by MuuMuu101
01/23/19 11:14 PM
My car is a pig!
by mprhound
01/23/19 10:40 PM
Any 1/18 scale Mopar collectors out there?
by Gabmando
01/23/19 10:28 PM
Dodge RB 440 crankshaft question-
by Tek52
01/23/19 09:54 PM
