Fuel/Brake Lines #954568
03/20/11 03:20 PM
03/20/11 03:20 PM
Under My Car
Mopar_Country Offline OP
Under My Car
I am going to put frame connectors in my Dart Sport and the fuel line is in the way on one side and brake line on the other. Is there a good source for a fuel line so I can reroute it along the inside of the frame connector when completed? Same with the brake line.
Re: Fuel/Brake Lines [Re: Mopar_Country] #954569
03/20/11 03:24 PM
03/20/11 03:24 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if the car is going to the track i don't think it will pass tech if you run a line inside a frame rail. i may be wrong though.
if your are going to splice the line almost any parts store has steel and aluminum lines.
perception is 90% of reality
Re: Fuel/Brake Lines [Re: Mr T2U] #954570
03/20/11 03:28 PM
03/20/11 03:28 PM
Under My Car
Under My Car
I'm not running it inside the frame rail, I want to route it along the frame connector on the inside surface versus the outer surface.
I would rather not splice if I don't have to.
Re: Fuel/Brake Lines [Re: Mopar_Country] #954571
03/20/11 03:35 PM
03/20/11 03:35 PM
Florida STAYcation
dIc dOc Deity ! Offline
The village idiot's idiot
Florida STAYcation
LET ME ADD .... is there any place you can get steel brake-lines in larger rolls than 25 feet ?
Re: Fuel/Brake Lines [Re: Mopar_Country] #954572
03/20/11 03:49 PM
03/20/11 03:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Its almost impossible to pull the lines through. I would install new lines first and depending on the connectors you can slot them to go over the lines. My connectors us car tool had slots in them. I painted the car first so now I will have to cut and flare in order to get them in.
Re: Fuel/Brake Lines [Re: NITROUSN] #954573
03/20/11 04:15 PM
03/20/11 04:15 PM
Under My Car
Under My Car
Again, I am not running the line inside of the connector, I am running it along the outside on the inner side of the connector. I thought about notching the connector, I don't like the idea but I may have to.
Re: Fuel/Brake Lines [Re: Mopar_Country] #954574
03/20/11 07:32 PM
03/20/11 07:32 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i believe that was they met that doesnt meet tech if its raced
