4 speed shifter mounting plate ID. #954553
03/20/11 02:53 PM
03/20/11 02:53 PM
MoPar Offline OP
MoPar  Offline OP
Hurst shifter mounting plate # 6348 what is the correct application ?
Re: 4 speed shifter mounting plate ID. [Re: MoPar] #954554
03/20/11 02:57 PM
03/20/11 02:57 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Originally used 68-70 B with hurst shifter, will also work 62-7 with hurst.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 4 speed shifter mounting plate ID. [Re: Dan Brewer] #954555
03/20/11 03:27 PM
03/20/11 03:27 PM
MoPar Offline OP
MoPar  Offline OP
Thanks Dan!
