Fixing cast? #954442
03/20/11 11:56 AM
03/20/11 11:56 AM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
Pulled apart the 440 today for my cam swap and after removing the waterpump housing saw that the top left mounting ear on the block had broke off that holds the pump and alternator bracket on top. I saved the piece that broke and was wondering what my options might be to fix? Don't know anyone around here that can weld cast so is there an epoxy that will hold up as long as I don't get carried away tightening the bolt? Thanks Moparts!
Re: Fixing cast? [Re: indytex96] #954443
03/20/11 12:51 PM
03/20/11 12:51 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
Most welding or machine shops should have a tig welder and some nickel rods.It also could be brazed on with a torch.
