Re: This look right? (relay question) [Re: Mr.Yuck] #953984
03/21/11 12:16 PM
03/21/11 12:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would most likely hook terminal 86 up to the ballast resistor
terminal 30 is hooked to battery power (starter relay)
85 goes to ground
87 goes to your pump
It sounds like for what ever reason your chosen switched power source isn't getting power.... Reason I'd use the ballast is you don't want power in accessory position like most stuff under the dash... & the relay draws so little power it won't effect anything.... I you want to have a over-ride switch to shut the pump down hook it up to terminal 85 so the ground is eliminated.. If you decide to add a inertia (crash) switch it also would go in the terminal 85 lead...
Re: This look right? (relay question) [Re: 1_WILD_RT] #953985
03/21/11 12:25 PM
03/21/11 12:25 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
85 goes to ground
Never thought of using the ballast. either side work? I think the Schematic had 30 going to the pump, 85 was ground, and 86/87 was to power and switch, can't remember which was which.
Re: This look right? (relay question) [Re: Mr.Yuck] #953986
03/21/11 01:02 PM
03/21/11 01:02 PM
GA
Boosted Offline
Boosted  Offline
GA
I run a constant voltage soleniod on my car. There is no need for a relay then. The constant voltage soleniod will only need 9v to activate it. Yhe pump will get full power then. Just a thought..
I run both of my pumps off the constant voltage soleniod.
And no it is not a ford soleniod.. They are not intended for constant power.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: This look right? (relay question) [Re: Boosted] #953987
03/21/11 01:19 PM
03/21/11 01:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
What exactly do you think that style solenoid is?
It's a relay with the ground circuit internally grounded...
As far as powering the trigger of the relay off the ballast, either would work but I'd use the battery side...
Re: This look right? (relay question) [Re: Mopar_Country] #953988
03/21/11 03:13 PM
03/21/11 03:13 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This helps me when using relays.
http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/relay.htm
I used dual 40 amp relays on my pump as recommended by Product Engineering as their pump draws some heavy current.
