Re: Cooling Q- 22" rad for mild 318? Other options?
[Re: Mopar_Country]
#953958
03/19/11 10:00 PM
03/19/11 10:00 PM
Posts: 3,378 KY USA
mopargem
KY USA
My challenger has a recent recore 22" 2 row with shroud and never ran hot all last summer with a slightly warmed over 383 and 323 gear. From past experience a shroud does help, so I agree try that first.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: radar]
#953960
03/19/11 11:06 PM
03/19/11 11:06 PM
RapidRobert
running hot at 70-80 MPH points to partly clogged/inadequate rad assuming the stat is not restricted (not opening all the way) but that's way less likely and you can pull the stat & take it back out & have the ans on that. Around town yes a tight fitting shroud on a 22" rad & a fixed blade metal fan ~2/3 of the way into the backside of the shroud would b the cheapest/simplest. I'm assuming the timing/mixture is in the ballpark. My 318 ('83) in a '65 Dart w an OE rodded out '65 dart 3 core 22"? w a high temp stat (forgot the temp but iirc it's over 200) runs almost too cool so w you I think the rad is somewhat plugged
