Cooling Q- 22" rad for mild 318? Other options? #953956
03/19/11 09:05 PM
03/19/11 09:05 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
I have a new 318 running in my '73 swinger (904 trans w/ stock high stall, mild cam). I put a 22" dodge radiator in it with a fixed 7 blade mopar fan.
Even breaking in the car cools well in easy conditions (40s outside, no extended idling or high rpm) but it gets a little hot (210) spinning 3.73s at 70-80mph and there's no shroud so it doesn't cool well in heavy traffic or in a drive through.
I am thinking about fabricating a shroud for it but I don't want to spend a bunch of time and energy just to find out it's still gonna overheat if I hit summer traffic.
Does anybody else have good luck with the 22" setup? Should I just grab a griffin or champion aluminum rad? How about a nice shroud with a strong electric fan? Of course that would need an upgraded alternator and a relay and ideally a fancy controller module ($$$)
So that's the parts I already have. What has worked for y'all? I don't want to spend $ if I don't have to but this car is mostly a cool beater for my wife to drive so I don't want her having problems.
radar
Re: Cooling Q- 22" rad for mild 318? Other options? [Re: radar] #953957
03/19/11 09:17 PM
03/19/11 09:17 PM
Under My Car
Mopar_Country Offline
Under My Car
A shroud would be a good place to start. I run a warmed 318, 180 t stat and it runs 180-185 even in 90* weather. Holds good temp even in traffic.
Re: Cooling Q- 22" rad for mild 318? Other options? [Re: Mopar_Country] #953958
03/19/11 10:00 PM
03/19/11 10:00 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
My challenger has a recent recore 22" 2 row with shroud and never ran hot all last summer with a slightly warmed over 383 and 323 gear. From past experience a shroud does help, so I agree try that first.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Cooling Q- 22" rad for mild 318? Other options? [Re: radar] #953959
03/19/11 10:02 PM
03/19/11 10:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
22" should be plenty. Look on 'bay for a shroud shouldn't cost that much. Also make sure you fan is close enough and you're not running too much timing.
Coming soon!!!!
Re: Cooling Q- 22" rad for mild 318? Other options? [Re: radar] #953960
03/19/11 11:06 PM
03/19/11 11:06 PM
running hot at 70-80 MPH points to partly clogged/inadequate rad assuming the stat is not restricted (not opening all the way) but that's way less likely and you can pull the stat & take it back out & have the ans on that. Around town yes a tight fitting shroud on a 22" rad & a fixed blade metal fan ~2/3 of the way into the backside of the shroud would b the cheapest/simplest. I'm assuming the timing/mixture is in the ballpark. My 318 ('83) in a '65 Dart w an OE rodded out '65 dart 3 core 22"? w a high temp stat (forgot the temp but iirc it's over 200) runs almost too cool so w you I think the rad is somewhat plugged
Re: Cooling Q- 22" rad for mild 318? Other options? [Re: RapidRobert] #953961
03/20/11 02:31 PM
03/20/11 02:31 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Thanks for the thoughtful answers. I'll try making a nice shroud before I spend $ on a new radiator or spendy electrical 'upgrades'
