Re: Centering rear end in chassis, anyone done this
[Re: ahy]
#953859
03/19/11 06:55 PM
03/19/11 06:55 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
In the past I've loosened everything up, attached a come along to force everything to one side then tightened everything up... On a current project I've got the spring pads cut off & it's definitely a better approach, things will center perfectly & won't be in a bind...
[Re: RodStRace]
#953865
03/20/11 08:05 PM
03/20/11 08:05 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
I'd measure the unibody too, it may be just a fender skin off or the whole thing off.
I did do a little measureing this way. Like from the outside of the framerail out to the edge of the fender. Its different on the two sides of the car. Its great, the precision with which our cars were built.
Doing some more measureing right now with the new wheels/tires on. I'll probably just try to move it to the right about 1/4" just to center it within the wheel wells a little better.
Heres what I'm looking at. This is the passenger side, measured with a tape measure I have 1" clearance.
[Re: DirectSubjection]
#953869
03/21/11 12:08 AM
03/21/11 12:08 AM
moparpollack
Lil Herman
Lil Herman
85086
My buddy's 71 Barracuda was the same way. Just poor sheet metal alignment. Hammer as needed and move on.
[Re: Mopar_Country]
#953870
03/21/11 12:44 AM
03/21/11 12:44 AM
MileHighDart
Lyons, CO
Is it an optical illusion or is the lip on the driver side a little wider than the other?
You must have really good eyes, cause I just went out an measured that. The pass side lip is slightly narrower, but just my maybe 1/16" depending on where exactly you measure it. Both lips are between 7/8" and 1". I could trim them both a little bit just for more clearance.
[Re: MileHighDart]
#953872
03/21/11 01:33 AM
03/21/11 01:33 AM
Posts: 377 Riverside, California
ghostrider
The entire driveline is supposed to be just slightly off center by design. Shouldn't cause you any problems to center it, the u-joints just work at the slightly different angle.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums.
Former Mopars include
69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
[Re: Mopar_Country]
#953873
03/21/11 08:34 AM
03/21/11 08:34 AM
Posts: 797 arizona, usa
lokalik
arizona, usa
sure looks like one is wider than the other. you could use masking tape and transfer the pass side to the drivers side to see how much you need to remove.
[Re: MileHighDart]
#953874
03/21/11 11:14 AM
03/21/11 11:14 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
ok... I have same "issue" on my Charger... IN FRONT AND REAR...
rear is small diff but in front I have around 1" difference being passenger side deeper into the fender
( and is not the only 73/74 charger I have noticed this )
