Tach wire thru firewall? (pictures please)! #951158
03/15/11 12:32 PM
03/15/11 12:32 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Getting ready to install a reproduction Tic-Toc-Tac in my 69 Super Bee. Not sure if it came out of the factory with one. My question is how did they run the coil wire thru the firewall? Hole on side of bulkhead with grommet? Or thru bulkhead? Thanks.
Re: Tach wire thru firewall? (pictures please)! [Re: superbeedave] #951159
03/15/11 12:39 PM
03/15/11 12:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Grommet through the firewall about 3" to the left of the bulkhead connector about the height of the bottom of the bulkhead connector....
Re: Tach wire thru firewall? (pictures please)! [Re: 1_WILD_RT] #951160
03/15/11 12:44 PM
03/15/11 12:44 PM
Cincinnati, Ohio
Cincinnati, Ohio
What size of hole is that 3/4" or 7/8"? I wonder why such a big hole for such a small wire?
Re: Tach wire thru firewall? (pictures please)! [Re: superbeedave] #951161
03/15/11 12:48 PM
03/15/11 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is a dimple in the firewall right next to the bulkhead, that is where the hole was PUNCHED. The hole size depends on the size of the big rubber grommet that is formed on the wire that goes under the dash and also the connector on the end needs to be able to be fed thru it also.
Sounds like your wire does not have this if you are asking why the hole is so big for such a small wire?
Re: Tach wire thru firewall? (pictures please)! [Re: superbeedave] #951162
03/15/11 12:55 PM
03/15/11 12:55 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
My 68 was a 3/4" hole.
Re: Tach wire thru firewall? (pictures please)! [Re: buildanother] #951163
03/15/11 01:02 PM
03/15/11 01:02 PM
Cincinnati, Ohio
Cincinnati, Ohio
JohnRR, Just a little ignorant with this. I never owned a Mopar with a Tic-Toc-Tac before. Yes I know! And I don't have mine yet so I really never knew! Thanks guys!
Re: Tach wire thru firewall? (pictures please)! [Re: superbeedave] #951164
03/15/11 01:09 PM
03/15/11 01:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You made it sound like you already have the tach and the wire kit .
Re: Tach wire thru firewall? (pictures please)! [Re: superbeedave] #951165
03/15/11 01:12 PM
03/15/11 01:12 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
