Engine vacuum... how do you test? #950950
03/15/11 01:19 AM
03/15/11 01:19 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Who knows where is the correct port to check for engine vacuum? I would think that it should be BELOW the throttle blades, maybe from the PCV port OR the power brake fitting.
I'm trying to dial in the BG 850 in the Charger. I need an accurate reading to have any chance of getting this right.
Thanks!
Re: Engine vacuum... how do you test? [Re: Kern Dog] #950951
03/15/11 02:24 AM
03/15/11 02:24 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The port for manifold vacuum on a Demon should be on the side of the base plate, towards the front side of the passenger side I believe. It should be a small size, like a vacuum advance port, so that your vacuum gauge will most likely fit right on. The one that gives a reading at idle is manifold vacuum, the other one is ported vacuum for your vacuum advance. I believe the more rearward one is for manifold vacuum.
Re: Engine vacuum... how do you test? [Re: GTX MATT] #950952
03/15/11 02:31 AM
03/15/11 02:31 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you have an extra port where the brake booster hooks up, that will be straight manifold vacuum after the throttle plates as you have guessed.
