Needle in a haystack, 4961 carb for 71 RR 383 M/T? #950774
03/14/11 08:00 PM
03/14/11 08:00 PM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
Anyone ever see one? I have been to Carlisle, Nats, Farmington, etc. I have yet to find one. What is the modern equivilant for my 71 383 4 barrel RR Manual Trans? (3 sp)What have you used for a factory type spec modern carb? Thanks, Greg ffgreg32@aol.com
Re: Needle in a haystack, 4961 carb for 71 RR 383 M/T? [Re: FFwithRT] #950775
03/15/11 11:39 AM
03/15/11 11:39 AM
P
Paul_Fancsali Offline
P
The closest equivalent is 600 Holley vac sec. The original carb was a 585 CFM. The original Holley was notorious leaker, the aftermarket 600 vac sec Holley the only changes I would make would be a purple or heavy yellow spring the jetting pretty much on the money. I would personally run 70s sec , but that requires a metering plate
Re: Needle in a haystack, 4961 carb for 71 RR 383 M/T? [Re: FFwithRT] #950776
03/15/11 01:50 PM
03/15/11 01:50 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Is that 4961 a Carter? Where did you get that number from? Please provide details. I always assumed that a Holley 4bbl was the correct one, a 4667 or a 6191.
