Jeep dead on road - HELP! #950720
03/14/11 07:30 PM
03/14/11 07:30 PM
middle of the country
aar1 Offline OP
aar1  Offline OP
Today my college age daughter was driving home for spring break on I70 thru MO. Vehicle is a 2004 Grand Cherokee V8 with almost 100k on it. After about 90 minutes of driving on the interstate, the thing just died. No warning, no stumbling.. just quit. After about 30 minutes, it refired and she drove it another 45 minutes or so.... it did it again. She nursed the jeep to Columbia MO to the Jeep dealer there. They ran a diagnostics on it and it came up clean........ no codes. She got a hotel for the night and the dealer will take it for a drive in the morning to see if they can replicate the problem. Without it throwning any codes, where should the dealer be looking? and thanks!
Re: Jeep dead on road - HELP! [Re: aar1] #950721
03/14/11 07:47 PM
03/14/11 07:47 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've had a crank or cam position sensor do the exact same thing to me twice. Wife was driving down the road and car just died. An hour later I showed up and it fired right up and she drove it home. In a week it did that 2-3 time when the first sensor was going. Finally it died for good and I replaced the sensor. Dave
Re: Jeep dead on road - HELP! [Re: quickd100] #950722
03/14/11 09:44 PM
03/14/11 09:44 PM
Would a bad crank or cam position sensor throw a code?
Re: Jeep dead on road - HELP! [Re: RapidRobert] #950723
03/14/11 09:46 PM
03/14/11 09:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not always.. I've seen a few bad ones on Fords with no code, I suspect Chrysler & GM will do the same.....
Re: Jeep dead on road - HELP! [Re: 1_WILD_RT] #950724
03/14/11 09:52 PM
03/14/11 09:52 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
I just went thru the same thing with my 96 grand cheerokee.Thing would just shut off when ever it felt like it no warning no codes.Turned out to be a crank sensor.
Re: Jeep dead on road - HELP! [Re: CARMAN] #950725
03/14/11 10:11 PM
03/14/11 10:11 PM
aar1 Offline OP
aar1  Offline OP
Anyone else got a thought? I'm gonna call the dealer first thing tomorrow (tuesday 3/15) morning and ask him is he has considered everything you guys are suggesting could be the problem. Thanks for all replys!!
Re: Jeep dead on road - HELP! [Re: 1_WILD_RT] #950726
03/14/11 11:04 PM
03/14/11 11:04 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
2.2 s-10's and anything with a Quad4 will do it without codes...and some 3800 v6's
Re: Jeep dead on road - HELP! [Re: SLOW67] #950727
03/15/11 01:05 AM
03/15/11 01:05 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Check the coil wire!!!!
Re: Jeep dead on road - HELP! [Re: fox] #950728
03/15/11 08:41 AM
03/15/11 08:41 AM
aar1 Offline OP
aar1  Offline OP
bump for the morning crew. Any more thoughts?
Re: Jeep dead on road - HELP! [Re: aar1] #950729
03/15/11 08:45 AM
03/15/11 08:45 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Crank Sensor, or Fuel pump,....maybe a clogged converter at worst, but my money is on checking the sensor or pump, as they can drop out intermittenly without showing a code, been there, done that
Re: Jeep dead on road - HELP! [Re: aar1] #950730
03/15/11 08:50 AM
03/15/11 08:50 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Sounds like fuel problem or coil..
Re: Jeep dead on road - HELP! [Re: bee71mopar] #950731
03/15/11 11:33 AM
03/15/11 11:33 AM
P
Paul_Fancsali Offline
P
Two times both fuel pumps no rime or reason?
