4 speed pedal assembly E body? #950573
03/14/11 03:19 PM
03/14/11 03:19 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Will a 4 speed pedal assembly from a 71 road runner bolt into a 71 cuda?
Re: 4 speed pedal assembly E body? [Re: RV2] #950574
03/14/11 03:39 PM
03/14/11 03:39 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
The main pedal bracket is different, but you can swap the B stuff into the E bracket and they are the same other than that.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
