Hey guys,
Went to take apart my brand new Meiling Oil pump to install a HP releif spring in it and found there was a core plug behind the cotter pin. I ended up drilling a hole in the plug to pull it out so i could change the spring. Now im wondering, can i reuse this plug even though it has a hole in it? or will I have to replace it with another plug? I still have the old oil pump in a box somewhere, was thinking maybe i can figure out how to get the plug outta that one if its the same
Any suggestions or ideas of what to do?
thanks!
Matthew
