Re: How to Fix or Diagnose 440 Hydraulic Lifter Problem
[Re: Pacnorthcuda]
#949426
03/12/11 08:09 PM
03/12/11 08:09 PM
Posts: 5,890 Athens, Greece
Pyper70
Athens, Greece
I went through and rebuilt all my lifters on my 440 on the Drivers bank after chasing a ticking sound (which ended up being the manifold warping)....All you need is a tub of oil 40wt...slip the lifter in, put an old push rod on the chuck and press it down (if you have a drill press...all the better)...use the tool to remove the keeper lock. take it apart...clean it....and then reverse the process....pump it a few times when you are done and slip it back in....since you go the cover off and don't have anything to do....do it to all of em...the others arent usually too far behind
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: skh]
#949429
03/12/11 09:48 PM
03/12/11 09:48 PM
RapidRobert
I'd replace lifters and cam. proper breakin procedure (want it to fire imediately, no less than 2500 rpm & goose it repeatedly during the 30 minute procedure)/good high zinc breakin oil/black moly paste on lifter bottoms/cam lobes and ahead of time mockup your new lifters in bores cleaned w brake kleen & lightly lubed w WD40 & lift each lifter up off of it's lobe w your finger & let it go & it should fall back onto the lobe w a resounding "thunk" which tells you the bore/lifter clearance is adequate so the lifters will rotate which is critical. If not hone them.
[Re: buildanother]
#949431
03/12/11 11:52 PM
03/12/11 11:52 PM
RapidRobert
OT those lifters w the mini hole can you drill them w a good hardened bit or does it require an EDM? machine? sounds like a simple/EXCELLENT way to keep the lobes lubed & there's a pressurized source right there, wonder why it was never thought of b 4
