HELP! ballast resistor getting hot with key off! #949418
03/12/11 07:21 PM
03/12/11 07:21 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
just replace the harness under the dash of my 72 satellite,everything now works,but the ballast resistor started getting hot and smoking with the key off.i checked the harness,didnt melt anything.what would cause this?
Re: HELP! ballast resistor getting hot with key off! [Re: 1bad318] #949419
03/12/11 07:23 PM
03/12/11 07:23 PM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
somethin not grounded?
Two wires touching
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: HELP! ballast resistor getting hot with key off! [Re: 1bad318] #949420
03/12/11 07:29 PM
03/12/11 07:29 PM
pull a batt cable & w your VOM on ohms see where the main line at from the fusible link on inside is connecting to the blue (ign1) circuit. I'm giving kind of a vague answer but as said above something touching somewhere (bulkhead/ign sw etc). What was the prob that you replaced the underdash harness?
Re: HELP! ballast resistor getting hot with key off! [Re: RapidRobert] #949421
03/13/11 12:16 AM
03/13/11 12:16 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
You have a shop manual?
wiring diagram?
12v test lamp?
Yank all the push-on ends off your ballast/ ignition and the ECU, and probe with a lamp and SEE WHAT'S HOT. Everything should be dead with the key off.
Then find out which wire (color) it is and trace back to the bulkhead. Yank that section of the bulkhead connector off, make sure it's still hot at the bulkhead--that will eliminate a "welded" harness short under the hood.
Next thin I'd do is yank apart the connector going to the column/ ignition switch, to see if it's in there.
Re: HELP! ballast resistor getting hot with key off! [Re: 1bad318] #949422
03/14/11 01:02 AM
03/14/11 01:02 AM
Maryland
reno340 Offline
reno340  Offline
Maryland
I highly reccomend one of these.
http://www.tooltopia.com/tool-aid-25300.aspx I Found a short with it in 10 minutes that had eluded me for 6 months.
Love this thing!!!!!
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: HELP! ballast resistor getting hot with key off! [Re: reno340] #949423
03/14/11 02:54 PM
03/14/11 02:54 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
thanks guys.i replaced the under dash harness cause the old was hacked up.im gonna replace the engine harness with a new one from year one also
