bb fuel pump not sitting flush. #949249
03/12/11 03:34 PM
03/12/11 03:34 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Switching Holley mechanical pump from my old engine over to the new engine...will not torque flush,i have literally pulled and reinstalled FP's many times on my charger because of a rusty tank...cant remember this problem.
Re: bb fuel pump not sitting flush. [Re: drumcat] #949250
03/12/11 03:45 PM
03/12/11 03:45 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
The only thing that comes to mind is the fuel pump is bad and the arm, if you will, will not move, as the lobe on the camshaft is in the outer position. If the arm on the fuel pump will not move, than I could see the pump not sitting flush. But if the arm moves okay, the only other thing I could think of is the pump is hitting the plug under it. You know the one that is there that you have to take out to put the rod in that goes from the cam to the fuel pump. All that I can think of, hope that helps.
Re: bb fuel pump not sitting flush. [Re: Dodgeguy101] #949251
03/12/11 03:55 PM
03/12/11 03:55 PM
california
drumcat Offline OP
drumcat  Offline OP
california
thanks,arm moves...when i turn the motor with a breaker i see no movement in the rod?
Re: bb fuel pump not sitting flush. [Re: Dodgeguy101] #949252
03/12/11 03:56 PM
03/12/11 03:56 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Rod fell down and arm is not on end of rod ,forcing pump up?
Re: bb fuel pump not sitting flush. [Re: RemCharger] #949253
03/12/11 04:01 PM
03/12/11 04:01 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
didn't think of that, that is a good answer..
Re: bb fuel pump not sitting flush. [Re: Dodgeguy101] #949254
03/12/11 04:06 PM
03/12/11 04:06 PM
Kirkland, Washington
Pacnorthcuda Offline
...also the pump is easier to install in the 'relaxed' position, if you bump the motor over 1/4 turn you may find it easier due the pump eccentric being on its base circle rather than its lobe.
Re: bb fuel pump not sitting flush. [Re: Pacnorthcuda] #949255
03/12/11 04:24 PM
03/12/11 04:24 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Remcharger that is the perfect answer/solution to the problem...i am acting an idiot, thank you all and sorry for wasting any of your time.
Re: bb fuel pump not sitting flush. [Re: drumcat] #949256
03/12/11 04:33 PM
03/12/11 04:33 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Didn't waste my time, glad someone helped you. That is what all this about. Take care.
