Rebuild kits #947663
03/10/11 07:15 AM
03/10/11 07:15 AM
Fitchbug, Mass.
WannaRunner Offline OP
Fitchbug, Mass.
Could someone give me a heads up on where to buy complete steering column rebuild kits? I have a '69 RR auto on the column with power steering...
TIA!
Re: Rebuild kits [Re: WannaRunner] #947664
03/10/11 11:06 AM
03/10/11 11:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm not sure if there is one , what parts do you need ?
Re: Rebuild kits [Re: WannaRunner] #947665
03/10/11 11:26 AM
03/10/11 11:26 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Not sure one kit exists, never seen or heard of one...the pot coupler may have one from the dealer - new shoes, seal, metal cover. The nylon sliders can be had from the dealer - same part as a Diplomat, 5th Avenue - green on color instead of the original white. Firewall seal - aftermarket has that covered. The column bearing - usually never go bad, just need a good cleaning and greasing.
Re: Rebuild kits [Re: JohnRR] #947666
03/11/11 02:37 AM
03/11/11 02:37 AM
Fitchbug, Mass.
Fitchbug, Mass.
I'm not sure what I'm going to need, this is my first rebuild. I guess I could go to the dealer for whatever isn't included in a rebuild kit.
Thanks!
