Part # help needed #947570
03/10/11 01:01 AM
03/10/11 01:01 AM
Connecticut
biginchmotor Offline OP
Connecticut
I need help with a part # for a 1974 Barracuda lower steering column bearing. The bearing is inside an aluminum collar at the base of the steering column tube. Does someone have an old parts book from 74? Local dealer has no way to look up the part #. Thanks John.
Re: Part # help needed [Re: biginchmotor] #947571
03/10/11 01:08 AM
03/10/11 01:08 AM
Under My Car
Mopar_Country Offline
Under My Car
Column shift or floor?
Re: Part # help needed [Re: Mopar_Country] #947572
03/10/11 01:14 AM
03/10/11 01:14 AM
Connecticut
Connecticut
I think it is a 4 speed column, John.
Re: Part # help needed [Re: biginchmotor] #947573
03/10/11 01:17 AM
03/10/11 01:17 AM
Under My Car
Under My Car
Re: Part # help needed [Re: Mopar_Country] #947574
03/10/11 01:35 AM
03/10/11 01:35 AM
Connecticut
Connecticut
It might, my bearing has no bolts, a clip and a spring is under it. I will check into that, thanks John.
