Will a 318 polly trans bolt up to a 318 LA engine? #947560
03/10/11 12:55 AM
03/10/11 12:55 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Can anyone tell me if a 1964-65 727 automatic transmission that is bolted up to a 318 Polly engine...also bolt up to a 318-340-360 LA Engine????
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: GLR] #947561
03/10/11 12:59 AM
03/10/11 12:59 AM
pretty sure it will
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: RapidRobert] #947562
03/10/11 01:02 AM
03/10/11 01:02 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
pretty sure it will
Oh yeah... with a solid recomendation like that, why not have one rebuilt and get a new converter while you're at it.
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: Kern Dog] #947563
03/10/11 01:04 AM
03/10/11 01:04 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yea...well guys...Sorry but I do need a Posative ..Yes or... No ...that they/you have personally done it or have a friend that has.
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: Kern Dog] #947564
03/10/11 01:05 AM
03/10/11 01:05 AM
Hey clown if you know if it will or if it wont then post it EDIT he's certainly not going to make or not make a purchase until he finds out definitely & my ans was to give him encouragement that the odds are very good that it will fit from when I dealt w one way back
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: GLR] #947565
03/10/11 01:06 AM
03/10/11 01:06 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: OzHemi] #947566
03/10/11 01:09 AM
03/10/11 01:09 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks Oz!...that ansyered my question!..
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: RapidRobert] #947567
03/10/11 01:14 AM
03/10/11 01:14 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Hey... a little touchy, huh? I guess you have the sense of humor of an engineer or accountant.
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: GLR] #947568
03/10/11 01:16 AM
03/10/11 01:16 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
No problem
Just did a quick search and found that....thought I had remembered something on it before..
Re: Will a 318 polly trans bolt up to a 318 LA engine? [Re: OzHemi] #947569
03/10/11 08:07 AM
03/10/11 08:07 AM
scratchnfotraction Offline
yes,I pulled a 65 polly 318 and installed a 67 318 on the same tranz
used the same TC
a 360 would need a correct balance TC to swap it in and be correct
the polly with swap a few parts to the LA318
crank
t-chain and cover
oil pump
flex plate
TC and tranz
fuel pump
just a few things I know of
