Re: Will a 318 polly trans bolt up to a 318 LA engine?
[Re: RapidRobert]
#947562
03/10/11 01:02 AM
03/10/11 01:02 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
pretty sure it will
Oh yeah... with a solid recomendation like that, why not have one rebuilt and get a new converter while you're at it.
[Re: Kern Dog]
#947564
03/10/11 01:05 AM
03/10/11 01:05 AM
RapidRobert
Hey clown if you know if it will or if it wont then post it EDIT he's certainly not going to make or not make a purchase until he finds out definitely & my ans was to give him encouragement that the odds are very good that it will fit from when I dealt w one way back
[Re: RapidRobert]
#947567
03/10/11 01:14 AM
03/10/11 01:14 AM
Kern Dog
Granite Bay CA
Hey... a little touchy, huh? I guess you have the sense of humor of an engineer or accountant.
[Re: GLR]
#947568
03/10/11 01:16 AM
03/10/11 01:16 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Thanks Oz!...that ansyered my question!..
No problem
Just did a quick search and found that....thought I had remembered something on it before..
[Re: OzHemi]
#947569
03/10/11 08:07 AM
03/10/11 08:07 AM
Posts: 15,487 Florida
scratchnfotraction
yes,I pulled a 65 polly 318 and installed a 67 318 on the same tranz used the same TC a 360 would need a correct balance TC to swap it in and be correct the polly with swap a few parts to the LA318 crank t-chain and cover oil pump flex plate TC and tranz fuel pump just a few things I know of
