Which Super Sucker works with 800 CFM Edelbrock carb #946933
03/09/11 07:34 AM
03/09/11 07:34 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
Wondering if any of the HVH Super sucker adapters have the correct bore diameter for an 800 CFM Thunder series carb -
Anyone tried one with an 800cfm Eddy carb?
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Moparmal] #946934
03/10/11 06:46 AM
03/10/11 06:46 AM
Moparmal Offline OP
Moparmal  Offline OP
Anyone?
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Moparmal] #946935
03/15/11 06:38 AM
03/15/11 06:38 AM
Moparmal Offline OP
Moparmal  Offline OP
Thought I'd try this one again- anyone used a SS with an Eddie 750 or 800 Carb?
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Moparmal] #946936
03/15/11 12:42 PM
03/15/11 12:42 PM
United States
STLDuster Offline
STLDuster  Offline
United States
seriously? no one?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: STLDuster] #946937
03/15/11 02:29 PM
03/15/11 02:29 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Reseachered there web sight. Depending on your manifold etc anyone that works with a holley 4150 series will work with your eddy.they are not throttle bore sized. Any sqaure bore carb will work.
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Cuda367] #946938
03/16/11 03:10 AM
03/16/11 03:10 AM
Moparmal Offline OP
Moparmal  Offline OP
I don't wish to doubt you - but why do they sell one for the 4150 and one for the 4500 if they don't work on bore size?
This is why I decided to ask - because they don't say why there's a choice..
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Moparmal] #946939
03/16/11 03:14 AM
03/16/11 03:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I don't know anything about it but since the 4150 & the 4500 have different bolt patterns..
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: 1_WILD_RT] #946940
03/16/11 06:36 AM
03/16/11 06:36 AM
Moparmal Offline OP
Moparmal  Offline OP
OK then - I know zip about Holleys so that may explain things
I've emailed HVH so hopefully they'll clear it up.
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Moparmal] #946941
03/16/11 03:20 PM
03/16/11 03:20 PM
Central NC
gch Offline
gch  Offline
Central NC
Any 4150 flange will work with an edelbrock.
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Moparmal] #946942
03/16/11 04:50 PM
03/16/11 04:50 PM
Worlds of differences in between the 4150, Carter,and Eddy square bore carbs compared to the Holley 4500 carbs Major differences, look at the spacer pictures of the two different types, 4500 on the left and 4150 on the right
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Cab_Burge] #946943
03/17/11 12:50 AM
03/17/11 12:50 AM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Really thought I had answered this. What I meant by not throttle bore sized is that there is not one for a 600 cfm holley or 650 eddy or holley or for a 800 cfm eddy or holley. Get the idea? there is just the one for 4150 series holley which interchange with the eddy. 4150 holley equals eddy. They do how ever have them for different style intake manifolds. pick the one that comes as close the the design of your manifold and for the 4150 series carb.
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Cuda367] #946944
03/17/11 05:31 AM
03/17/11 05:31 AM
Moparmal Offline OP
Moparmal  Offline OP
No problem..with the program now.
And thanks everyone for all the help - their website doesn't even mention Edelbrock, so unless you ask..its go figure on how they size them.....
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: Moparmal] #946945
03/17/11 09:23 AM
03/17/11 09:23 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Are these carbs a square or spread bore carb? 4150 is square bore.
Alan Jones
Re: Which Super Sucker works with 800 CFM Edelbrock carb [Re: LA360] #946946
03/21/11 02:54 AM
03/21/11 02:54 AM
Moparmal Offline OP
Moparmal  Offline OP
Square bore AVS
