67 Belvedere dash light issues #946766
03/08/11 11:51 PM
03/08/11 11:51 PM
NY
clemul Offline OP
clemul  Offline OP
NY
I have gremlins in my gauge lights and headlights..I replaced the headlight switch and the voltage regulator is a new solid state from rt engineering. If i put my signal on it works fine but if i put the headlight on when the signal is on the signal indicators don't blink. I put a ground wire from back of headlight switch to column but no change. Any suggestions to help make tomorrows task of chasing down the causes a lot easier? my front fender mounted signals and bumper mount signal indicators do not come on. Thanks for any and all help....
Re: 67 Belvedere dash light issues [Re: clemul] #946767
03/10/11 12:53 AM
03/10/11 12:53 AM
Andrewh Offline
Andrewh  Offline
I would guess switch.
did it just start? or did it do it after you changed the headlight switch?
My bet is it is the wrong one.
