Eastwood Rust Desolver #94619
07/25/08 10:19 PM
07/25/08 10:19 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Does anybody have the instructions for Eastwood Rust Desolver handy?? I have some but the label is gone. If I remember right, keep wet for 15 mintues and then rinse with water. The water put is whats got me wondering????
Thanks for the help, gonna use it tomorrow, blasting, treating, priming and painting my front suspension. The black parts anyway.
Careful, your character's showing!
Re: Eastwood Rust Desolver [Re: mopar346] #94620
07/25/08 11:03 PM
07/25/08 11:03 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Room temperature, heat speeds it up, plastic soak tank preferred, pre-clean item, do not use any other chemicals or solvents to pre-clean, rinse item and immerse, length of time varies depending on severity of rust, light surface rust requires 5-30 minutes, moderate rust up to 4 hrs, deeply rusted parts overnight, check progress periodically, some items not fully immersed may experience carbon etching at the water line, rinse with water, for short term rust inhibition, dip in rust dissolver and allow to dry. I don't recommend to do that...it's better to spray a light coat of MP-50 or equal for temporary rust inhibition for the natural look or you can clean and paint or coat the part later. It also loses it's oomph after a few uses.
Re: Eastwood Rust Desolver [Re: RoadRunnerJD] #94621
07/26/08 08:14 AM
07/26/08 08:14 AM
mopar346 Offline OP
mopar346  Offline OP
Thanks, time to go to work!
