Jeep Patriot CVT trans fluid change #946142
03/08/11 03:15 AM
03/08/11 03:15 AM
Detroit, MI
GetAwayDriver Offline OP
Detroit, MI
A friend has a Jeep Patriot with the CVT trans (sealed). Mileage is 85K, owner's manual says change at 65K (true?). Dealer wants $500 for the job. Sounds pricey, but I don't know much about the CVT trans.
What advice would you give?
Re: Jeep Patriot CVT trans fluid change [Re: GetAwayDriver] #946143
03/08/11 04:16 AM
03/08/11 04:16 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Choice is yours weather you want to follow the manual.
The CVT trans fluids are very expensive. Is there a replacable filter and is that being offered in the service. Should be about 1 hour job just for fluid exchange. Seems like $400 for fluid and maybe filter. Probably 10 quart exchange so that's $40/qt. Crazy as it sounds, that could be possible.
Nissan GT-R trans fluid is about $90/qt DEALER cost!!
My guess it would be a screw on filter if there was one.
Re: Jeep Patriot CVT trans fluid change [Re: GetAwayDriver] #946144
03/08/11 06:21 AM
03/08/11 06:21 AM
places
79powerwagon Offline
places
Re: Jeep Patriot CVT trans fluid change [Re: 79powerwagon] #946145
03/08/11 12:28 PM
03/08/11 12:28 PM
Detroit, MI
Detroit, MI
http://www.jeeppatriot.com/forum/showthread.php?t=22944
Thanks for both replies... Sounds like the quoted cost is on-par.
(Although I'd definitely be doing it myself if I owned one!)
