Edelbrock aluminium head build with Indy parts #943958
03/06/11 09:48 AM
03/06/11 09:48 AM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Hello,
The guy from a shop has offered to me Eddy heads build with Indy valves and Pro comp springs and other performance parts for the same price as the Eddy heads with its original parts.
He says that they had troubles with the eddelbrock valves and these are better.
I asked him if they build these heads in their shop and he replied to me that they come from Indy who buys eddy heads as bare castings and build them with other better parts.
Are somebody running these kind of heads?
Are they really better than the ones with eddy parts?
These are the specs:
1 paar edelbrock performer cylinder head
8 x Ad. valve MPI-V1-27653 - 2,14"
8 x Ex.valve MPI-V1-27656 - 1,81"
ALL-V3-82604 - Spring Cup
ALL-S2-G911 Comp Camps Valve Spring
ALL-R1-82303 7 degree steele retainer
ALL-L3-PF-555-HD 7 dergree locks
ALL-V3-11/32 Valve stem seal
Cylinder Head Style Assembled
Cylinder Head Material Aluminum
Cylinder Head Finish Natural
Combustion Chamber Volume (cc) 84
CNC-Machined Combustion Chamber No
Intake Runner Volume (cc) 210cc
Exhaust Runner Volume (cc) 70cc
CNC-Machined Intake Runner No
CNC-Machined Exhaust Runner No
Combustion Chamber Style Closed chamber
Intake Port Location Standard
Exhaust Port Shape Rectangular
Exhaust Port Location Standard
Intake Valves Included Yes
Intake Valve Diameter (in) 2.140 in.
Exhaust Valves Included Yes
Exhaust Valve Diameter (in) 1.810 in.
Valve Springs Included Yes
Maximum Valve Lift (in) 0.600 in.
Outside Diameter of Outer Spring (in) 1.550 in.
Damper Spring Included No
Number of Springs Per Valve Single
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Valve Stem Seals Included Yes
Valve Stem Seal Style PC seal
Rocker Arm Studs Included No
Rocker Arms Included No
Rocker Arm Nuts Included No
Guideplates Included No
Valve Cover Mounting Style Perimeter bolt
Accessory Bolt Holes Drilled No
Valve Guides Included Yes
Valve Guide Material Manganese bronze
Valve Seats Machined Yes
Valve Seat Machine Style 3-angle
Valve Seat Material Ductile iron
Steam Holes Drilled No
Oiling Style Through head
Machined for O-Ring No
Heat Crossover No
Thanks a lot for your help.
Re: Edelbrock aluminium head build with Indy parts [Re: Coke] #943959
03/07/11 05:17 PM
03/07/11 05:17 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Indy's standard valves are NOT as nice as what Edelbrock supplies with their own heads. I see nothing about those Indy-built Edelbrock castings that makes me think you're better off w/ their "package" head than an out-of-the-box Edelbrock.
Re: Edelbrock aluminium head build with Indy parts [Re: PorkyPig] #943960
03/09/11 08:58 AM
03/09/11 08:58 AM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Ok, thanks for the input
Re: Edelbrock aluminium head build with Indy parts [Re: Coke] #943961
03/09/11 11:17 PM
03/09/11 11:17 PM
tucson az
frank Offline
frank  Offline
tucson az
I had a set of these heads. Eddy RPM's bought from Indy with Indy parts. I bought them because Indy sold them cheep. I would not do again. I had the heads looked at by my machinist and he told me the parts Indy put in the heads were not quality pieces; You get what you pay for. I had to get new valves, springs, retainers. Additionally the valve job Indy did was not as good as I was lead to beleive.
Re: Edelbrock aluminium head build with Indy parts [Re: frank] #943962
03/10/11 09:06 AM
03/10/11 09:06 AM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Thanks a lot Frank,this helps a lot.
Yes, i know people who are running the original eddy heads without troubles,so i will go for the safest way and will order them.
This is just becasuse always is better to get the opinion from the mates before to spend all those bucks.
Thanks again .
