Re: Is a bigger carb worth it ?
[Re: T-bar]
#943277
03/05/11 06:54 AM
03/05/11 06:54 AM
Posts: 30 Australia
Charger VJ RB
Australia
I would keep everything except the converter, get one made to suit your combination.
RB XE274H Q-850
[Re: Charger VJ RB]
#943278
03/05/11 08:05 AM
03/05/11 08:05 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Just as an example, our Challenger with an old 440, Indy SR headed, torquer 2 intake motor picked up 4mph and 3/10ths in the quarter going from a 850 to 950 carb. Same day, back to vack swap and no other changes, cam was a .509 using 1.6 arms (.543 theoretical lift) the 850 carb was pretty well scienced out too. So I would say yes, a 1050 dominator may hurt street manners though and would require a different manifold which may bring about hood clearance issues. I'd look at a custom 4150 for your application. HTH's Tig BTW, The converter used in the above combo was a 10 inch B&M holeshot. Stalled around the figures you've posted. I agree a converter change would pick it up some too. Rear gear was 3.91, very similar combo barring cubes and lift.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#943280
03/05/11 01:25 PM
03/05/11 01:25 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
What ET's and MPH's was the car running before and after? Were they both at the same A/F ratio??
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#943281
03/05/11 04:26 PM
03/05/11 04:26 PM
Tig
A shed in England
On the morning we had 4 - 5 runs with a best of 12.17 @ 111mph But mainly in the 12.20's. In the afternoon we only got one run with the new carb which was in the 12.00's @ 114ish (Cant remember exactly) Plugs looked a little lean so we upped the jets 2 sizes. Next day we had 4 runs. We ran a 12.00, 2 11.90's and a 11.85 @ 115.5 before breaking out but we were happy to do so , IIRC we went up another 2 jet sizes all round after the first pass. We didn't run an AFR gauge back then, seat of the pants and plug checks HTH's Tig
