1950 Ply 2dr. post #941843
03/03/11 08:49 AM
03/03/11 08:49 AM
Pa, USA
ronw Offline OP
ronw  Offline OP
Pa, USA
Has anyone changed the rear on this car with a newer 8 3/4 and do how you get around the drive shaft that bolts to the three speed trans and rear? I want to keep the orginal flat six and three speed manual. Thanks Ron
Re: 1950 Ply 2dr. post [Re: ronw] #941844
03/03/11 12:24 PM
03/03/11 12:24 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Any good driveshaft shop should be able to build something for you.
The ball and trunion is not the best in terms of boot replacement and servicing. If you can replace it with a slip joint, you would probably be better off. Discuss this with your driveshaft person.
