Fuel sending unit #940273
02/28/11 11:21 PM
02/28/11 11:21 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I am researching a fuel tank for my 34 Dodge coupe and the tank I am looking at comes with my choice of three different sending units. 0-90 OHM, 70-10 OHM, and 240-33 OHM. The gauges also come set up for the different sending units. I know I will be fine as long as I get matching gauge and sending unit. My question is, is there an advantage to one of these three OHM ranges, or just pick one and go with it?
Arno
Re: Fuel sending unit [Re: B1arno] #940274
07/09/11 02:36 AM
07/09/11 02:36 AM
PA
bbrroowwnn Offline
bbrroowwnn  Offline
PA
It doesn't matter as far as I know....The main thing is you match the sending unit with the gauge so the gauge will read accurately.......If you are unsure which sending unit to get do what I did....I recently bought a set of used gauges and had no idea what sending unit to use with the fuel gauge as there was no instructions....So I just got some resistors in the values you listed from radio shack, a 9 volt battery, and a few small pieces of wire and hooked them up to the gauge to see what I had....Turns out I had a 10 ohm 70 ohm....bought the proper sending unit already in the fuel cell and now I am good to go
