Why won't she start!
#939459
02/27/11 11:41 PM
02/27/11 11:41 PM
Posts: 9 Fallon, Nevada
Youngun
Fallon, Nevada
So here's the deal,
I have a street 440. All the following ignition parts are brand new: Summit CD ignition, Summit ready to run billet distributor, MSD wires, MSD blaster coil, autolite plugs.
The problem: While turning over, NOTHING happens. No spark at the plugs or even the coil and the ignition box LED light does not indicate the trigger signals are going to the coil like it should by blinking.
So far I have found: I can get a spark from the coil by jumping the magnetic pickup wires, so the coil must be good and the ignition is capable of delivering a "fire" signal to the coil. There is voltage going to the distributor via the magnetic pickup + wire, but nothing comes out of the distributor to send a trigger signal to the ignition box. I'm not sure who makes the distributor, but the wierd thing is (for a mopar) it has 3 wires coming from it wired as follows:
BLACK (grnd) RED (+) connected to the mag + from the ignition (VIOLET) ORANGE (-) connected to the mag - from the ignition (GREEN)
I have not checked the gap between the reluctor and pickup, could this be the problem?
Any help would be appreciated!
(Here's the car for some eye candy, finally 98% complete after 7 years and lots of help from Moparts)
